Thread: Pump suggestions
    Apr 2011
    GA
    Default Pump suggestions
    The PoolForum and PoolDoc recommend against the purchase of SpectraLight, EcoPump, Leaf Pump or ZeoPure products, or any products sold on websites affiliated with the email address [email protected], or the parent company name "SpectraLight Technologies". Due to legal threats, we cannot say more at this time. No further discussion of these product lines is allowed. Somewhat more information is available on in this post.
    Hi. We have had our pool for a year, it came with the house we bought. The pumps on it (a normal pump and a booster pump) were both pretty old. We already replaced the booster pump last year. Now the main pump is getting louder quickly. The current pump is 1hp. I am looking for suggestions on replacing it. Are the Ecopumps that I found for real? Are they worth it? If not what other suggestions do you have?
    Thanks,
    Aaron
    Default Re: Pump suggestions
    Dunno what an "Ecopump" is, so can't comment on that.
    Regarding appropriate pump replacements you'll need to first supply info on
    * # of gallons in pool
    * type and size of filter
    * size of piping.
    Ben / PoolDoc
    One company to look at is Hayward. Can't tell you specific models, but they are a very reputable company. I'm sure Poconos will be along later to add his bit. He'll be able to give you some advice that may help.
    Largo, Florida
    I recently replaced my pool pump and was underwhelmed by the options. You can always go with a "bigger" pump or a multi speed pump but other than that it's not like there's 20 brands out there each trying to outperform each other. In the end I spent $250 to get pretty much the exact same pump i was replacing. Surprisingly, my local pool store had it in stock for exactly the same price I had found it for online.
    It seems like pool equipment is an area ripe for a small company to come along with good products and clean up. For whatever reason, when I buy parts it always seems like I end up with the big companies like Hayward though... As pooldoc mentioned, too many scammers ruining it for everyone else I guess.
    Apr 2011
    GA
    Thanks for that. I am probably going to go with the Hayward northstar series one. Any thoughts or comments on them?
  1. Any suggestions for a Pentair Meteor pump...
    By YenkoDeuce in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 09:55 PM
  2. suggestions ?
    By smgchandler in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-08-2010, 10:35 PM
  3. Hiding/Softening pool pump/noise suggestions
    By sahara in forum In-Ground Pool Construction and Repair
    Last Post: 09-09-2007, 05:31 PM
  4. Suggestions on Pump to Filter Connection
    Last Post: 07-16-2006, 10:50 PM
  5. suggestions re: heat pump?
    By farmgirl in forum Pool Equipment & Operations
    Last Post: 05-01-2006, 04:31 PM
