Thread: Cloudy water
    May 2010
    Default Cloudy water
    Pool has been cloudy for a while so I started shocking it once the weather started to warm up. It never went away and I finally had a chance to test it today.
    Ph - 7.6-7.7
    TA - 130
    FC - 5
    CC - 0
    TC - 5
    CH - 1000+ (I just stopped at this point)
    CYA - 20+ (used all of it and could still see the dot)
    Thanks for any help!
    Default Re: Cloudy water
    Your calcium hardness level is WAY too high and I'm sure is most likely the reason for your cloudy water. Your other numbers are ok except the TA is a little high which is also most likely adding to the problem. I'd be willing to be that you are shocking with cal-hypo and if so, stop. Just use plain bleach for your source of chlorine as it will not cloud the water. The only way to drop the calcium hardness reading is to do a partial drain and refill. Do NOT totally drain your pool. What type of pool is this?
    Also, could you define "shocking"? To get to a true shock level with a CYA of 20, you need to get your chlorine up to at least 15 ppm.
    I agree with Watermom, though--looks to me like your calcium is the culprit!
    May 2010
    It is an inground plaster pool. I know not to drain the entire pool, the guy that re-surfaced it told me what happened to a customer that did. haha
    How much is a partial drain?
    By shocking I was putting in a couple of scoops (the big blue DE scoop) of granular shock for a few days just trying to get the chlorine level up to kill what I thought might be algea.
    Thanks for the input!
    I would think you could drain as much as 1/3 to 1/2 at a time without a problem--as long as there's at least 2-3 feet of water in the shallow end I think you're fine. Alternately, one of the other mods has posted a "sheet" method, where you take a large piece of plastic and pump from underneath as you refill from the top so that the pool basically stays full throughout the process.
    In order to shock the pool, you really need to be measuring the chlorine levels instead of just dumping "some" chlorine in and hoping for the best--your method may work sometimes in a hit-and-miss way, but to get reliable results you really need to measure your levels to keep them where they need to be and to get rid of the algae.
    You definitely need to stop using cal-hypo at this point, though--I suggest you switch to plain, generic bleach. How many gallons does your pool hold?
    May 2010
    I will go to plain bleach.
    A quick online calc shows my pool is 19,200. It's a free form that is 16'X32' with a 3' shallow and an 8' deep.
    Time to drain!
    In 19,200 gallons, each 1.5 gallon of bleach should raise your chlorine by 5 ppm. Each 1.5 quart should raise your chlorine by 1 ppm. (That's 6% strength).
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
