Re: Tired of bad advice from pool company
So help me understand what you're saying, - even with a 150+ CYA level, do I need to drain/refill? And you suggest to "see how fast your CYA drops". I thought the CYA never drops. So I remain in that confused state I started in. What is the resolution to the CYA levels? Leave it as it is and monitor FC levels and forget about it? Drain? Not drain?
