Thread: intex pool to solar heater valve
    Default Re: intex pool to solar heater valve
    stneasy --- We usually recommend that people not list their email addresses on the forum. There are harvesters out there that snatch up email addresses and flood you with spam or worse. I edited your post and removed it. By the way, welcome to the forum.
    What kind of Intex pool do you have? I used to have a 15' donut with the little 1/6 hp cartridge filter. I had very little trouble hooking up a 10'x4' solar panel to it, just using that little pump. I did have to get fittings to mate 1.5" plumbing required by the panel to 1.25" plumbing used by the pump and pool, but that was it. By adjusting down the flow to the panel I maintained the water velocity necessary on the return and STILL had the panel bring the pool temp up to over 100 deg!
    May 2012
    Minnesota
    We've have used heater panels with both our intex pools. Just takes some head scratching, replacing intex hoses to pool store ones, some of those clamps u use a screwdriver to tighten and some rubber couplers. Time at the hardware store in the plumbing n outdoor irrigation depts. not as pretty but heat is worth it. We also upgraded to a 1hp Hayward pump n a sand filter. When cash strapped you tend to get creative
    13.5K gal 24' x 52" Intex Ultra AG pool; 1hp Hayward pump and Hayward sand filter; (2) 4'x20' Solar Heating Panels; 1 Firepit heater system and a Raypak 2100 Propane Heater that I can't afford to use anymore.
    Sep 2012
    South Eastern Utah, USA
    My solar heating panels have a 3 way shut-off valve that came as a recommended part when my husband set up the solar panels. This way I can run the pump with or without circulating pool water through the solar panels. We'll be hooking the solar panels up tomorrow. I can't wait to go swimming.
    16x32 rectangle 14.6K* gal Intex AG vinyl pool; Household Bleach; Sta-Rite System 2 cartridge filter; Waterford Systems 1 speed pump; 8 hrs; Taylor K2006, HTH 6 way test strip; well; summer: none; winter: intex provided cover; android phone; PF:8.2
