Re: Fighting the Mean Green
With a CYA of 70, you need to be chlorinating up to 20 ppm, not 12. The 12 ppm was good while you had no CYA, but now that the CYA is that high, you need to compensate with higher chlorine levels. I strongly encourage you at this point to switch over to bleach, because the dichlor is adding a lot of CYA, which you're going to have to compensate for all summer by keeping higher chlorine levels. In a pool your size, each 1 1/2 quarts of regular, 6% bleach will raise your chlorine by 1 ppm. So to get it from 15 to 20, you'll need roughly 2 gallons. Once you achieve the proper shock level for your CYA, and if you can hold it there consistently, most messes can be cleaned up in just a few days. However, if you don't get it up to the 20 ppm now that your CYA is high, you'll be fighting this for a very long time. At this point, I would not add any more dichlor--just switch to plain bleach to finish the job!
