Results 1 to 10 of 53
Thread: Opened pool and problems...
    Default Re: Opened pool and problems...
    Looks like you're making progress!! Keep it up!! Sometimes it just takes awhile for the filter to get it all. If your pressure is still rising while the pump is running, and goes back down again after backwashing, then your filter is catching the stuff.
    May 2011
    Ok, so I'll keep going but do I let the Chlorine go down at this point to maintenance level? Also, should I think about upping the cya? Is it time to do anything about the high TA?
