Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 53 of 53
Thread: Opened pool and problems...
  1. #51
    Default Re: Opened pool and problems...
    Looks like you're making progress!! Keep it up!! Sometimes it just takes awhile for the filter to get it all. If your pressure is still rising while the pump is running, and goes back down again after backwashing, then your filter is catching the stuff.
    May 2011
    Ok, so I'll keep going but do I let the Chlorine go down at this point to maintenance level? Also, should I think about upping the cya? Is it time to do anything about the high TA?
  1. Opened pool
    By 392papa in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-21-2013, 09:27 AM
  2. Just opened pool and trying to use BBB, am I doing it right?
    By naturegirl in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-20-2011, 06:12 PM
  3. opened to green pool
    By shanode in forum Dealing with Algae & Slime
    Last Post: 05-14-2008, 07:55 PM
  4. No kit yet -- Opened Pool -- What Should I do?
    By AnnaE in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-21-2006, 08:40 PM
  5. Okay...new to this..just opened pool..need help
    By albertgarrido in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-21-2006, 10:19 PM
