Re: Pool plumbing question (1.5" to 2")
I know this is an older post but I'm considering a similar upgrade and trying to determine if it is worth it. Pool is 16'x32' roughly 20K gallons I believe. I have a new Pentair Superflo VS variable speed pump Model 342001. All of my eyeball fittings are the flexible nozzles that change diameter as the pump speed increases.
The pool has two 1.5" suctions lines (one from the bottom drains and one from the skimmer) that come above ground to a hard tee then go into the pump with 1.5" piping. The entire system is 1.5" piping then it splits off to two 1.5" zones of return jets (one that has 2 jets at the steps and one that has 4 jets at other locations).
I'm an engineer type and I would have thought the improvement going from 1.5" to 2" for the above ground piping would be dramatic. Those tees seem like a serious choke point.
