Re: pool opening
I have been adjusting the Chlorine for two days now. Here are my new numbers. My CYA was higher then originally posted. Would it be o.k if I let it go down on it's own over the summer? I realize I will need to keep my Chlorine levels higher. What is the downside? Chlorine levels loss less then 1 over night. The water is clear. Trying to keep shock level at 25. Thanks,
FC= 23.5
CC= 0
PH= 7.4
TA=100
CYA= 100
