Thread: First results of test kit
    daverothwell is offline ** No working email address ** daverothwell 0
    Ashburn Virginia USA
    Default First results of test kit
    Hi all:
    My first test results:
    FC 14
    CC .5
    TC 6
    pH 7.5
    Alk 150
    Cal 300
    Cya 100
    Temp 74
    38,000 galls white plaster inground in N Va.
    Appreciate your comments...
    Dave
    Default Re: First results of test kit
    Welcome to the forum!
    How does your water look? Your chlorine readings aren't quite right. FC + CC always = TC. Test those numbers again. PH, alk, and cal readings are fine. Your cya is really high at 100. I suspect you have probably been using trichlor pucks to chlorinate with? You have two choices. You can either do a partial drain to lower your cya level or you can live with it that high, but you'll have to run higher than normal chlorine levels as a result or else you're gonna have algae problems. I would suggest just using bleach as your source of chlorine as it will not make your cya climb. Take a look at the following link. Repost after you recheck chlorine levels and also tell us exactly what all you have used in this pool.
    http://www.poolforum.com/pf2/showthread.php?t=365
    Hi again:
    Ok - 10 days after my first set of readings (been travelling) the results are:
    FC 10
    CC 0
    TC 6
    pH 7.5
    Alk 120
    Cal 300
    Cya 100
    I'll leave the Trych pucks for a while and just use bleach....
    Dave
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
