Thread: Heyward CL100ABG install
    May 2011
    Default Heyward CL100ABG install
    New pool installed in Oct and this is the first opening. I have read these instructions several times for the chlorinator and nothing seems to match up with the filer I have. I have a Proclean Single cartridge filter with the original ribbed flexible tubing and the PVC going from the pump to the filter. The chlorinator is the off line model and I am having difficultly determining where the inlet and outlet tub should be connected to the filters tubing. Are the any good diagrams out there? Any thoughts would be helpful - Thanks!
    Default Re: Heyward CL100ABG install
    Want to help but it seems we need more info? You have an 'in-line' chlorinator that you put tablets/pucks in? Or something else? You specifiy your filter but what is the model of your chlorinator? This link may help http://www.poolplaza.com/pool-school..._feeders.shtml The two in-line chlorinators I helped neighbors with were both after the hose comes out of the filter and before it goes into the pool. Of course we don't have heaters here in TX; maybe chillers? Hope this helps some.
  1. New AGP Install
    By bradatkins in forum Above-Ground Pool Construction & Repair
    Last Post: 09-10-2012, 01:46 PM
  2. liner install help?
    By jazzbone in forum Above-Ground Pool Construction & Repair
    Last Post: 05-16-2010, 07:55 PM
  3. Should I install SWG myself???
    By Plane_guy in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2006, 01:17 PM
  4. Replacing pressure gauge on Heyward sand filter
    By Zaphod in forum Pool Equipment & Operations
    Last Post: 06-18-2006, 09:52 PM
  5. Question About AG Install
    By glepage in forum Above-Ground Pool Construction & Repair
    Last Post: 06-07-2006, 07:53 AM
