You'll do fine testing. The directions are pretty clear. The only test that is a little hard to read is the CYA test, but since this is a fresh fill, you already know you don't have any CYA so don't need to run that test. You can usually buy muriatic acid at a home improvement store. Ben suggests you put it in a garbage bag for the ride home. The fumes are pretty potent!
