Thread: up and running- now what?
    Mar 2011
    Ohio
    Default up and running- now what?
    have been following this site for over a year now and trying to follow your wisdom. 30 ft round AG with new sand filter and 1hp super pump. winter cover came off middle of COLD december thanks to a neighbors dog, but thats another story. So I have my taylor K2006 test kit (purchased thru your link) and these are my first readings. FC.5 CC1.5 PH 8.0 + took 10 drops of R005 to get to 7.2 TA 120 CYA less than 30 what I have done is added 26 gallons of 12% pool store shock (on sale 9.99 case) and added two boxes of borax. filter is and has been running non-stop past 24 hours.Really thought clorine would be higher since you can smell it around the pool. maybe I messed up the test it did take me 8 dips of 0870 powder to turn sample pink. what now??
    Mar 2011
    Ohio
    Default Re: up and running- now what?
    adding 12 gallons BLEACH and no more borax unless told otherwise. sand filter PSI holding steady at 8. pool looks 1000x better than last week
    Mar 2011
    Ohio
    ok not really 12 gallons (3 qt jugs) so 9 gallons also have not added DE to filter since I thought I would be backwashing every day but thats not happening. So glad to open pool already wife just turned FURNACE back on. Gotta LOVE this OHIO weather
    The chlorine smell is probably coming from the high CC reading. Continue to keep it at shock level until the CC level drops to 0.5 or below. Did you run the pH test before or after you added a large dose of bleach? If it was done after, it is most likely inaccurate. If it was before, then it is too high and you'll need to lower it some with muriatic acid. Start with a cup or so added slowly in front of a return jet being careful not to spill or splash it and staying upwind of the fumes. Also a good idea to wear protective glasses. It is nasty stuff. Wait several hours, retest and redose until you get the pH somewhere between 7.2-7.8.
    Glad to have you here on the forum and thanks a lot for becoming a subscriber! Hope this helps.
    (BTW -- if you think of something you need to add or a typo that you need to correct soon after you make a post, you can edit it by clicking the edit button below the post.)
    Mar 2011
    Ohio
    thanks for that tip now FC 18 CC 1.2 all readings were done after my adds I need to check in the a.m. and compare FC correct? keep adding bleach until no more than 1ppm drop off from night/a.m.? At what point will the PH be accurate? thank you for assisting
    Mar 2011
    Ohio
    so this mornings check FC 15.5 CC 3 did not test for anything else or should I ALWAYS test for everything? why did CC double? is that normal?
