Results 11 to 15 of 15
Thread: Cloudy water won't clear up
    Jun 2010
    Southeast
    Default Re: Cloudy water won't clear up
    Is the lateral assembly supposed to sit on the bottom of the filter? The old one was just a little more than half way down. The top of the down pipe was cracked so I repaired it and extended it so that it sits on the bottom.
    I'm not sure--you might need to see if you can find an exploded view of your filter via the internet. I found one for mine, before I started taking it apart......
    Jun 2010
    Southeast
    Well it's been about a week I got the filter back running and am using DE in it and today I can see the pattern on the bottom of the pool, finally I can see the light at the end of the tunnel.
    Thank You all for your help
    Apr 2011
    virginia
    Great! We got to use our pool all day Sunday- friends over, good BBQ, etc... you should be there soon!
  1. Water is cloudy. Want to clear up before closing
    By Jacob99 in forum Dealing with Algae & Slime
    Last Post: 09-29-2012, 07:38 PM
  2. Clear up cloudy water
    By bross1990 in forum Dealing with Algae & Slime
    Last Post: 07-26-2012, 02:59 PM
  3. Crystal clear water but turns cloudy once swimmers get in
    By joelq in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-15-2007, 04:30 PM
  4. Cloudy water on Clear Comfort
    By densar24 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-22-2006, 11:39 AM
  5. Can't clear cloudy water
    By ScrltOTara in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-02-2006, 08:44 PM
