Results 1 to 10 of 10
Thread: k2006 test kit
    May 2011
    centralcalifornia
    Default Re: k2006 test kit
    below is the description of the kit as stated on a google search. says it tests .5 to 5.0 ppm chlorine??
    Description:A Complete Dpd Test Kit Designed For Service People, Commercial Pool Operators And Health Dept Officials Interested In Economy & Portability. Tests For Free & Total Chlorine (.5 - 5.0 Ppm) Bromine (1.0 - 10 Ppm), Ph (6.8-8.2), Acid Demand, Base Demand, Calcium Hardness, Total Alkalinity And Cyanuric Acid. Uses 3/4 Oz Reagents. Plus Titrants To Improve Accuracy.
    I'd buy the K-2006C from the Amazon link which is sold by Amato Industries. It is the same kit as the 2006 but has larger quantities of some of the most often used reagents. The kit will test way higher than 5.
    Quote Originally Posted by fhorta View Post
    The kit you describe here is the K2005 not the K2006 recommended here. The difference is that the 2005 uses DPD which only measures up to 5 whiole the 2006 uses FAS DPD and can measure to ~ 50 ppm. (the FAS DPD is also a LOT easier to read)
    If Amato Industries is out of them, you can also get the K2006 at this link https://shop.spspools-spas.com/Taylo...-and-Reagents/.
    Price is $55.00 + shipping, which isn't bad....
    This is where I buy most of my replacement reagents, and I've found their prices to be competitive and have never had any trouble with them.
    May 2011
    Coral Springs, FL (SE Florida - near Fort Lauderdale)
    Kind of a stupid question, but do the 2 oz bottles fit into the standard K2006 box?
    May 2011
    Didn't think so. That would have made life easy. Thanks!
    My pool:
    15x30 inground concrete pool w/spa in one corner overflowing into pool, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter
    Jandy Laars LX400 propane heater w/120 gal above-ground tank
    Jandy AquaLink RS OneTouch controller w/PDA remotes and computer control
    JVAs control pool/spa switch and also allow drain opening
    Hayward Navigator
  1. Pool test smackdown: Taylor K2006, OTO, Pinch-a-Penny, Pool Store
    By famousdavis in forum DPD-FAS based testing
    Last Post: 07-25-2011, 11:47 PM
  2. readings from new k2006 kit(finally!)
    By rgomez in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-23-2011, 11:32 AM
  3. k2006 and CC
    By fhorta in forum DPD-FAS based testing
    Last Post: 07-22-2011, 08:32 AM
  4. I have my K2006, now have questions...
    By blessedbeingmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2010, 08:47 PM
  5. CYA Test with Taylor K2006 - CYA over 200!
    By ubalr1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-08-2006, 09:04 AM
