Hey Kath!
You can address the wall issues at any time, sand them down and Rustolium *TM* spray paint them, to keep the rust at bay. I'd wait until the liner is delivered to fix the floor, any rain or strong winds will effect the floor, so you want to only have to retrowel it once, just prior to putting the liner in. I can give some tips on retrowling sand, but it will take me some time to type it and I'm not sure when my next day off is.
I wouldn't use 'play sand' it's too expensive - go to a building supply place or quarry and get 'dead sand' or 'mason's sand' @ ~ $.10/ pound. You can use 5 gallon buckets or the plastic tote bins to put it in. If you need a lot of sand, you can line a pickup truck bed with plastic and have them use a bobcat to toss a scoop in the back (a bobcat scoop is ~ 2000 lbs.).
