Re: Cloudy water plan of action
wsommariva
Something to do with water conductivity.
You are right, low TDS mean low conductivity and that means that CHLORINE CANNOT BE GENERATED IN THE CELL JUST LIKE WITH A SWCG! You unit is producing a small amount of chlorine as an oxidizer in the cell along with the copper BECAUSE OF RESIDUAL SALT IN YOUR WATER (TDS). It is not unlike the Ecosmarte system and it is SNAKE OIL! We have been through all this on a different forum already.
Your water is cloudy because something is growing in it unless your DE filter grids are damaged. On another forum you stated that your pool became cloudy after running the filter for a day but it was crystal clear before you turned the filter on. I told you to inspect the grids but you insisted that the grids were fine! In that case something is growing in the water to cloud it.
You needed the metal stain remover and sequestrant you used because you are putting metal into your pool. Don't have to be a rocket scientist to figure that one out! Fiblerglass pools are notorious for staining (it's their main drawback) so metal ionizers are NOT a good idea. There is some empirical evidence that keeping the calcium hardness up in a fiberglass pool can slow or prevent staining from metals and cobalt spotting but the jury is still out. It can't hurt, IMHO.
Also, we have been through most of this on the OTHER forum that you post in quite a bit (where I am a Moderator) so I am not sure why you thought you would get different answers here. You have gotten the truth in both places. Whether you choose to believe it or not is your decision.
Sorry if I seem a bi short but this is really a rehash for me. Perhaps you will start to believe now that you are hearing it from other sources as well and stop believing all the marketing hype on the ClFree website.
