Results 1 to 10 of 25
Thread: Cloudy water plan of action
    May 2011
    Default Re: Cloudy water plan of action
    Thank you Carl. Seems from Ben's chart FC might be similiar in both cases. Maybe a dumb question, but is CL generated by a SWCG the same as CL in tablet form?
    Chlorine from a SWCG is sodium hypochlorite, same as liquid chlorine and bleach. Your unit is not a SWCG and will not generate enough chlorine to be able to keep your pool chlorinated properly (as chem geel already stated).
    Tablets are generally trichlor, a stabilized form of chlorine that addes 6 ppm CYA for every 10 ppm of FC added.
    All forms of chlorine form hypochlorous acid (Free Chlorine) and hypochorite ions in the water, the difference between them being what else they add (and if these additions can be detrimental) and the effect they have on pH.
    Generally, with a SWCG FC is kept at 4-5 ppm and CYA at 80 ppm.
    In a manually (and this includes automated chemical feeder systems, chlorinators, and floaters) chlorinated pool (chlorine source does not matter, btw) IF the CYA is in the "normal" range of 30-50 ppm then generally FC is kept at 3-6 ppm.
    IF the chloirne source is a stabilized chlorine (dichlor granules or trichlor tabs) then the CYA will continue to rise with useage since both of these also add CYA to the water. Dichlor adds 9 ppm for every 10 ppm FC added and trichlor adds 6 ppm for every 10 ppm FC.
    May 2011
    Thank you.
