Just want to make sure that I have adequate sized equipment.
10,000 gal fiberglass. 1.5 hp pump and 36 sq ft PE filter.
Other considerations for pump size would be if you also have a spa, water feature or anything else that might need higher flow rates. If not, then I agree with everyone else that you can go with the smallest pump possible.
