Results 1 to 10 of 14
Thread: fill water test results
    Apr 2011
    Default fill water test results
    Hello everyone,
    Finally got my pool installed, filling it now and it's about half full. I have a 16x32 oval Doughboy. 300 lb. sand filter, 1 1/2 hp pump. I tested fill water and these are my results:
    FC: 1.8
    CC: 0
    PH: less than 7.0. color is more yellow than pink
    CyA: 0
    TA 90
    According to the pool calculator I should be prepared to add:
    Bleach 63 oz.
    Borax 171 oz.
    Baking soda 26 oz.
    stabilizer 76 oz.
    I realize I should completely fill and let the pump run for 3 or 4 hrs. and recheck before adding anything. But am I at least on the right track?
    Thanks for your input,
    Wayne
    Apr 2011
    Default Re: fill water test results
    my volume is 13,700 gallons
    You are on the right track. I'm just going to tweak some of the amounts that I would add if it were my pool.
    Adding that much bleach is only going to increase your chlorine reading by about 2.2ppm. The problem with that is since this is a new fill with no cya in the pool yet. your chlorine level is going to disappear fast, especially on a hot, sunny day and leave you vulnerable to an algae bloom. I'd suggest taking your chlorine up to 5 or 6 since it isn't going to stick around long. For the first few days, you may need to add chlorine 2 or 3 times per day. After about a week when your cya has had a chance to dissolve totally, you'll be able to test and dose it with bleach in the evenings only.
    Your alk is OK at 90, but if you want to take it up just a little higher, then the amount you listed is fine.
    I always like to aim a little low on cya. Easier to add more in a week if you aren't where you want to be than to overshoot your target. Maybe a little less than 76 oz. Then, retest in about a week and go from there.
    Since your pH is so low, I'd add one full box of Borax slowly to the skimmer breaking up any clumps. After 3 or 4 hours of letting it circulate, retest pH and add more as needed. Anywhere between 7.2-7.8 is ok. I like between 7.4-7.6 for my pool. I wouldn't add 2 boxes all at once, though. It is usually better to go with smaller doses rather than one big one.
    Hope this helps!
    Apr 2011
    Thanks for the help,
    after adding 4 bottles of clorox and 1 box of borax and letting it circulate for a couple hours here are my results
    FC: 15.4
    Ph : looks to be slightly less than 7.0
    TA: 100
    CC: 0
    calcium hardness: 60
    I have 30 oz. of stabilizer hanging in a sock by the return line.
    I don't think I should be worried about the FC being high as I'm sure it will be coming down fast with no stabilizer. Correct?
    Thanks again,
    Wayne
    I'd probably go with about 3.5 lbs. of stabilizer for starters. See how high that takes it in about a week. (Don't test sooner than that or else you're just wasting your reagent.)
    I wouldn't take the FC so high. You are right that with no stabilizer it will come down fast, but I wouldn't take it that high. Don't want to risk bleaching the liner.
    Watermom's absolutely correct. FC's high if the pool is clear because your CC is 0. pH is low. T/A should be ideal. Calcium is irrelevant, unless it's too high--and that doesn't happen till it hits 400.
    Figure your pool at 13,700 gallons if your water depth is 4'. For quick calculations you can use 13,500 or even 14,000 and there will be no significant difference.
    If your pool is clear, I'd let FC come down to 5, but no lower than 3 (I just am paranoid about levels under 3ppm).
    Apr 2011
    My numbers this evening,
    FC-10.5
    CC 0.5
    PH 7.0
    TA 100
    water is starting to look a little cloudy. I can't seem to get the PH up. I added another 50 oz. of borax today, and also aerated for a couple hours today and didn't help.
    Wayne
    You only have to wait about 2 or 3 hours after adding Borax before testing pH again and redosing if needed with more. Keep testing and adding bleach a few times per day and run your pump 24/7 if it is looking cloudy. You'll get there.
    Apr 2011
    After adding the borax yesterday I ran the Polaris 64 for several hrs. It releases excess pressure at the return line so it also does a fair job of aerating. I can see the bottom but my water still looks cloudy with a slight yellowish tint to it. I almost want to add some bleach but my FC is still high. Also it is not falling as much as I expected. Should I remove the sock with the stabilizer? I didn't check the CYA yet because it's only been a couple of days since I added the stabilizer ( one sock full dissolved already). Anyway my numbers this morning,
    FC: 9.5
    PH: 7.4
    TA: 110
    CC: 0 (maybe I did this wrong yesterday, it wouldn't just drop without doing anything would it?)
    How do you subscribe to this forum?
    Wayne
  1. Testing fill water - strange results
    By tado921 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2013, 10:57 AM
  2. Fill with only 1 foot of water and don't fill for 24-48 hours?
    By Jacob99 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-26-2012, 07:00 PM
  3. First water test results
    By Daggit in forum DPD-FAS based testing
    Last Post: 11-02-2006, 02:49 PM
  4. my fill water test
    By gordyjamz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-23-2006, 02:09 PM
  5. New Pool Set up...Inital fill test results
    By weluvstuff2 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-18-2006, 11:48 PM
