Hi all, Thanks for any help. I have tried to recover my pool from the green monster and I feel I have had success. After maintaining a shock level of 15-20 PPM my pool wen t form green to a cloudy blue. Now I am having fits getting the pool clear. Here are my levels from this morning.
FC = 24ppm (level was held overnight!)
CC = 1ppm
PH = 7.8
TA = 60ppm
CYA = 0
Tested with Taylor Kit recommended by this site.
I have been attaining the shock level using HTH's granulated chlorine, I used this because I had it from last season and I'm not worried about my CYA level getting elevated by it. The pool has been this color for the past 4 days. I continue to shock, sweep and run pumps and backwash when needed.
Pool facts:
15,000 G
Sand Filter
Vinyl Lined
You can add a handful through the skimmer, give it about 30 minutes and check your pressure--you're looking for no more than a 1 psi rise in pressure. The DE will help coat the sand, and will help catch the finer stuff. It will wash out when you backwash, though, so you'll have to add more after a backwash.
