What you are doing is working; stay the course. Backwash your filter as needed.
Sunday ~8:45 a.m., May 29, 2011 (Day 4)
Our pool looks about the same as last evening – bluish in color with lots of settled debris, and some signs of seeing the bottom in the deep end. However, the water sample does have a smell of chlorine.
Water temp = 70 deg.
FC = 8.4
CC = 1.4 (5 x 1.4 = 7.0 good!)
pH = 7.5
TA = 50
I’m not quite sure as to why the CC level has risen – other then an error in the testing process?
My best guess is that I need to add 4.3 gal. of chlorine (bleach 6%) this a.m. (in order to keep the FC level elevated throughout today), then test / adjust the chlorine levels later this evening in order to determine if the FC level remains stable overnight (or maintains a 5:1 ratio with CC).
Many “thanks” for all of the helpful recommendations I have received from the PoolForum, especially the latest from both Ben & Watermom,
Gene
PS – I will backflush this a.m. in hopes of reducing the pump pressure.
The chlorine you are smelling is the combined chlorine (CC). Go ahead and hit with bleach again this morning if you haven't already done so. An hour or so after you do so, test and see what kind of chlorine numbers you are achieving. Also, *if* there is any debris that can be scooped out, go ahead and remove it.
First – Many thanks for your response Watermom!
The following 2 entries comprise my latest post to the PoolForum.
Sunday ~1:45 p.m. , May 29, 2011 (Day 4)
I can actually see the deep end of the pool – with lots of dead matter (I assume) laying on the bottom all over the pool! Water tests were as follows:
FC = 0.2 – 0.5 ppm (way down from just 4 hrs ago!)
CC 1.5 ppm
pH = 7.2
Pump pressure ~ 19lbs (after back flushing)
I DID NOT add the 4.3 gal. of chlorine (bleach 6%) earlier today – our local WalMart was out of stock (and it was time for church)!
The FC is really a lot lower then just ~4 hrs ago! I tried both 10ml & 25ml water sample for the chlorine testing, with only a slight difference in the nos. (which I would guess is to be expected).
By not adding the additional chlorine (bleach 6%) earlier today the overall conversion process has probably once again been delayed – bummer! Plans are to now add 7.1 gal. of chlorine (bleach 6%) in order to make-up for some lost time & the low FC level!
Sunday ~ 7 p.m. , May 29, 2011 (Day 4)
Our pool water is clear with a bluish tint (liner, sky, etc.), and you can see the main drain in the deep end. However, there is a lot of foreign matter on the bottom of the pool – and the water it’s self has a chlorine and/or bleach smell.
Water temp = 75 deg.
FC = 7.5 ppm
CC = 1.5 ppm (5 x 1.5 = 7.5, OK)
pH = 7.2
Two things come to mind, 1) I really messed up by not adding the chlorine (bleach 6%) this morning (like I said I was going to do!), and 2) with the much warmer & sunnier days, I should have been adding stabilizer 90% / conditioner to the pool water – the sun / UV is just killing the FC! So…I’ll retest in the a.m. (Monday), and go from there! Have a Great Memorial Day - and enjoy your USA Freedom!
Gene
PS – Does anyone have a recommendation as to a ‘brand name to buy’ for the stabilizer 90% / conditioner (cyanaric or isocyanuric acid)? Which may only be available from pool store? I should have ordered this product when I ordered the test kit (date wise)!
If you can, I'd wait a bit to add the CYA. Maybe you don't work tomorrow since it is Memorial Day and will have time to test it and add bleach every couple of hours? The more often you do it, the faster you'll get the conversion over with. I would also suggest taking the FC a little higher. Since the high cl reading isn't going to stick around long, it isn't going to be a concern about hurting your liner. Go ahead and take it on up to about 10. A couple hours later when you test, take it back up to 10, repeat, repeat, repeat. We have had people in the past who have gotten through their conversion quickly because of how often they added bleach.
We usually suggest getting a pool cleared up before adding CYA. As far as what brand to buy, I doubt it matters. As long as you buy cyanuric (or isocyanuric) acid, it will be fine.
Watermom,
“Thank you” for your response with regard to the CC odor, as well as the time frame as to when I should be concerned with the CYA level. The settled debris is too fine to scoop out, maybe spring pollen or just plain old dirt from over the past winter / spring months? Additionally, I’m working on increasing / keeping the FC level much higher (~10) then it has been recently. Missing the chlorine dosage yesterday morning did not help matters!
As of this a.m. our pool looks cleaner, including the deep end, except for the all of the debris settled on the bottom. The water sample had a slight odor / smell, and the early test results are as follows:
Water temp = 74 deg.
FC = 5.0 ppm
CC = 1.5 ppm
pH = 7.2
With the FC dropping over night by 2.5 ppm, and the ratio <5 when compared to CC, I added another 4.34 gal. of chlorine (bleach 6%). My plans today are to re-check the chlorine levels ever 2-3 hrs.
“Thank you” (and everyone) for taking your time to read and to share your experience!
Gene
Hopefully with testing/shocking every couple of hours, you'll make a lot of progress today. Typically, I think, when people stay on top of their conversion with frequent monitoring and additions of bleach, most people finish the process in a week or less.
