Re: Steps - Switching from Baquacil to Chlorine
First – Many thanks for your response Watermom!
The following 2 entries comprise my latest post to the PoolForum.
Sunday ~1:45 p.m. , May 29, 2011 (Day 4)
I can actually see the deep end of the pool – with lots of dead matter (I assume) laying on the bottom all over the pool! Water tests were as follows:
FC = 0.2 – 0.5 ppm (way down from just 4 hrs ago!)
CC 1.5 ppm
pH = 7.2
Pump pressure ~ 19lbs (after back flushing)
I DID NOT add the 4.3 gal. of chlorine (bleach 6%) earlier today – our local WalMart was out of stock (and it was time for church)!
The FC is really a lot lower then just ~4 hrs ago! I tried both 10ml & 25ml water sample for the chlorine testing, with only a slight difference in the nos. (which I would guess is to be expected).
By not adding the additional chlorine (bleach 6%) earlier today the overall conversion process has probably once again been delayed – bummer! Plans are to now add 7.1 gal. of chlorine (bleach 6%) in order to make-up for some lost time & the low FC level!
Sunday ~ 7 p.m. , May 29, 2011 (Day 4)
Our pool water is clear with a bluish tint (liner, sky, etc.), and you can see the main drain in the deep end. However, there is a lot of foreign matter on the bottom of the pool – and the water it’s self has a chlorine and/or bleach smell.
Water temp = 75 deg.
FC = 7.5 ppm
CC = 1.5 ppm (5 x 1.5 = 7.5, OK)
pH = 7.2
Two things come to mind, 1) I really messed up by not adding the chlorine (bleach 6%) this morning (like I said I was going to do!), and 2) with the much warmer & sunnier days, I should have been adding stabilizer 90% / conditioner to the pool water – the sun / UV is just killing the FC! So…I’ll retest in the a.m. (Monday), and go from there! Have a Great Memorial Day - and enjoy your USA Freedom!
Gene
PS – Does anyone have a recommendation as to a ‘brand name to buy’ for the stabilizer 90% / conditioner (cyanaric or isocyanuric acid)? Which may only be available from pool store? I should have ordered this product when I ordered the test kit (date wise)!
