Re: Steps - Switching from Baquacil to Chlorine
Madwil,
Thank you for your comments - they are always helpful!
When you say, “remove FC first” I assume you mean by adding the R0781 drops until the water sample is colorless, which is what I have been doing. However, if there is a short time delay (making notes, etc.) until the 5 drops of R-0003 are added – the water sample will usually take-on a pinkish color? So…would you just add the R-0003 or go back and add some additional drops of R-0781? Would you happen to know of a better method of testing the CC at the lower end?
Gene
