Results 1 to 10 of 40
Thread: Steps - Switching from Baquacil to Chlorine
    May 2011
    Middle TN
    Smile Re: Steps - Switching from Baquacil to Chlorine
    Thursday, June 2nd 6:45 a.m. (Day 8)
    Throughout the day on Wednesday the FC level was keep elevated by adding multiple dosages of chlorine (bleach 6%) based on the records from the prior 2 days – with only 1 water test was completed (8:30 p.m.).
    The pool looks crystal clear Thursday a.m., with only a slight amount of noticeable debris on the bottom – mostly in the shallow end? The Polaris has managed to pickup most of the courser waste material – and the skimmer sock continues to clean up the usually Baquacil gook! Test results as of today;
    WT = 81 deg.
    FC = 20 (~ same as 8:30 p.m. on Wednesday)
    CC = 0.5ppm
    pH = 7.6
    Pump Pressure = 26lbs
    Based on the above test numbers, and primarily with the CC <= 0.5 ppm, I decided to start the process of changing out the filter sand today – preceded by brushing, raising the water level, vacuuming, and taking a few photos as well.
    Many “Thank You” to all of you on the PoolForum who have taken your time to respond to my posting – your comments, advice, and guidance is always appreciated,
    Gene
    May 2011
    Middle TN
    Default Re: Steps - Switching from Baquacil to Chlorine
    Thursday, June 2nd 6:30 p.m.
    Watermom - you are "very welcomed"!
    Changing the sand within the filter went OK, what a mess!, and it took longer then thought it would. Backwashed & rinsed, restated circulation at 4:30 p.m. – with some visible sand later in the pool? - not sure why?
    The following readings were taken at 6:30 p.m. (2 hrs after re-starting pump)
    WT = 83 deg.
    FC = 0.5 ppm (really low based on the reading this a.m.?)
    CC <= 0.5 ppm
    pH = 7.1
    TA = 45
    CH = did not test
    CYA = did not test
    With the pH at borderline low, I will add the following;
    pH - 7:30 p.m., add 1 lb of soda ash (Borax)
    TA – 9:00 p.m., add 2 lbs of baking soda (A&H)
    FC – 10:30 p.m., add 1.42 gal of chlorine (bleach 6%)
    Plans for early a.m. on Friday include 1) vacuum sand from bottom of pool, 2) complete a comprehensive water test, and 3) almost certainly add 1-2 lbs of stabilizer / conditioner (via sock in strainer).
    Any and all comments with regard to correct steps to balance our pool, now that the BaquaGoo is finally gone, would greatly appreciated and “Thank you”
    Gene
    Gene,
    Since this original thread is in the Baquagoop forum and you have finished your conversion, I'm going to suggest that you copy and paste your most recent post and start a new thread in a more appropriate forum. This thread is really long and it will just make it easier for all involved. Besides, there are some people who never look at the threads in the baq. forum so you'll get more viewings in a different section than you will in this one. After I see that you have, I'll delete this last post and lock this thread so people don't start responding to it here.
    Thanks.
    Please do not add any further posts to this thread. Gene is going to start a new thread in a different section of the forum. Thanks. Watermom
    pictures posted of a relatively easy conversion.
    EDIT by Watermom: The pics Ben added today are in post #24.
