Hi,
We bought a house in beginning of May and has an inground pool. The pool has a leak and have asked two different pool guys to come and fix it. I did a test myself of troubleshooting first, by closing all the jets and skimmer drains, but the pool level still dropped with the system off. I was convinced there must of been a hole in the liner.
The first guy told me it was the skimmer after running a pressure test, but that does not make much sense to me since the water lever drops to about 1/2" above the skimmer front plate (bottom)...so there is always some little water in the skimmer, but just not enough to run the system.
I asked for a 2nd opinion, and this guy tells me it's the liner, but he has not found/showed me any holes.
Can I do any real testing myself? I did not expect to have this added cost/problem. The kids were excited to start swimming, so this is a big dissapointment. The city we live in has a bylaw that if we need to fill a new pool we need to get a water truck, so I want to avoid emptying and refilling pointlessly also.
What more can I check? Please send me some suggestions. Should I start by shocking the pool (it's all green still)? Will this help me find problems or run a dye test myself? Can it be something simple like the skimmer faceplate?
) of bleach can fix!
