I can try to take some pictures if that will help?
You can send a pic to poolforum AT gmail DOT com
Is it the skimmer basket or the skimmer pipes that are silted up?
It's the pipes, there are 2 pipes below each basket, i can make 1 of the 2 pipes work by turning the "Skim" lever off and the "Vac" lever on but if I have the Vac on the Main Drain doesn't work....
I had a clog in my skimmer yesterday that I was able to free with a 25' snake that you would use to unclog any plumbing line inside your house.
Where could I get one of those?
The snake thing
Home Depot. Standard Plumber's snake. I have one for many years now, long before I had a pool (I'm a tool junkie).
