Results 1 to 10 of 14
Thread: high PH
    Sep 2010
    Chicago, IL
    Default Re: high PH
    Its cloudy and green. I just opened it.
    Its a liner pool. 35000 gal.
    Default Re: high PH
    Keep the chlorine at shock level and run the pump 24/7 to clear it up. Don't use any stabilized forms of chlorine (trichlor or dichlor). You do not want your CYA any higher than where it is now.
    Sep 2010
    Chicago, IL
    Default Re: high PH
    after I add the acid - how long should I wait to add more chlorine? Can I do them around the same time?
    Default Re: high PH
    You don't want them to mix, in concentrated form is the general answer.
    "An hour" would be a reasonable specific answer that should keep you safe . . . as long as the pump is running during that hour.
    Ben
    Sep 2010
    Chicago, IL
    Default Re: high PH
    Awesome - thanks guys.
    Also - Ben can I have a few more privs? I don't see any sigs and had to hunt for the Amazon link to buy the kit so you get the contribution towards the site. I'll even try to click through that to buy other stuff too so you can get that referral bonus.
    Sep 2010
    Chicago, IL
    Default Re: high PH
    I did find one on Pool Solutions and ordered, but like I said I order a bunch on Amazon and would love to contribute that way and as I learn this stuff from you awesome, awesome people I hope to contribute by passing the knowledge on down. Today at the pool store I told a guy waiting in line that I use household bleach and he was like "huh? what? really??" Also told him that "shock" is a verb. :-)
