Results 1 to 10 of 35
Thread: Pool Still green after 20 gals of bleach...1st time post.
    May 2011
    SouthEast Virginia
    Default Re: Pool Still green after 20 gals of bleach...1st time post.
    Got the garden hose sophoning now. Gonna try vac hose with shop vac on it!!
    Uhh, no, don't do that. Shop vacs aren't made for sucking water out of pools.
    Do you have just a plain pool vacuum hose (for hand vacuuming the pool)? Use that.
    Ben
    What Ben said!
    May 2011
    SouthEast Virginia
    Should've been more specific. I used the shop vac to start the sophion on the larger diameter pool hose. Worked quite well.
    Pool is now drained with only 12-15 inches left. I turned on the hose lastnite. This am it is about 1/2 full so between today and Monday I should be able to get it filled up.
    I need some replied to my thread about my sand filter in that section please.
    Thanks for the help we are gaining on it.
    May 2011
    SouthEast Virginia
    She's full and filtering over nite I will do the Taylor kit in am. The strips showed fc and tc still at top of the chart tonite. Cloudy water but I can see the bottom.
    May 2011
    SouthEast Virginia
    Monday numbers
    FC 14
    cc .5
    TC 14.5
    ph 7.0
    alk 125
    CYA 50-60
    by the best guess I need to run 5-10 ppm
    I need to shock 20 ppm
    using cya table 60-90 to be safe.
    Do I raise it to shock table now to lower cc?Water is cloudy with light green tint. Filtered over nite and have no intentions to turn off.
    Yes, because of the greenish tint--I would raise it to shock value now and keep it there until the pool clears, and until you can measure chlorine at sundown and again at sunup without losing any chlorine,.
