Thread: Valve has small leak
    May 2011
    Jeffersonton, VA
    Default Valve has small leak
    We are renting a house that has an inground pool. We have everything up and running, however, the valve that operates the two skimmers has a very small crack in the bottom of it. We were wondering if there is a simple way to repair this...like with an epoxy or something else? Please help!!! We have already put a lot of time and money into this inground pool and we are ready to enjoy it!
    Default Re: Valve has small leak
    The answer to your question is a very firm "MAYBE".
    If you can take a set of pictures of the valve, from multiple sides, both at a distance and close up, Poconos or I (or maybe Waste or Waterbear) can probably tell you what your options are. Mail the pictures to poolforum AT gmail DOT com, and I'll upload and link them.
    Ben
    Welcome to the Forum!
    A crack in the body of the valve means it's gotta be replaced or 'band-aided' Do you know the brand of the valve? - Jandy valves come with a life time guarantee.
    If replacing the valve isn't an option, I can tell yo how to properly epoxy putty it. If you want to replace the valve, I can give you a few tips on 'playing' with PVC piping.
  1. Small leak at pump / motor
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 12-28-2012, 11:37 AM
  2. Can Small Leak Prevent Pump From Priming?
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 07-24-2007, 10:36 AM
  3. Small Filter Leak
    By Orkalovesfood in forum Pool Equipment & Operations
    Last Post: 06-06-2007, 10:44 PM
  4. small filter leak
    By pcasey61 in forum Pool Equipment & Operations
    Last Post: 05-15-2007, 05:02 PM
  5. Small Leak in Spa Air Line
    By jmce1587 in forum In-Ground Pool Construction and Repair
    Last Post: 03-08-2007, 02:52 PM
