Thread: Pool Drainage question
    May 2011
    Las Vegas
    Default Pool Drainage question
    I have the 18x24 and love it but need to drain it. Does anyone know if there is a way to hook it up to the hose with some kind of adapter? I need to get the water from the backyard to the front drain Via hose.
    Default Re: Pool Drainage question
    If you aren't in a hurry, and your pool is above the level in the front yard, you can just use a long water hose to siphon the water from the pool and drain it to the front.
    If your pool is inground or below the level of the front, you can buy a small sump pump (~$70) and pump it there, over a couple of days.
    Ben
  1. drainage around AGP
    By link6 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-12-2011, 06:56 AM
  2. Pool Surround Drainage Questions
    By Gynot in forum In-Ground Pool Construction and Repair
    Last Post: 06-04-2010, 04:33 PM
  3. Pool drainage under the deck and around the shell
    By cbucner in forum In-Ground Pool Construction and Repair
    Last Post: 05-17-2010, 07:32 AM
  4. Above ground pool drainage....
    By rrivera62 in forum Above-Ground Pool Construction & Repair
    Last Post: 03-29-2006, 12:49 PM
