Results 1 to 10 of 22
Thread: My algae issues
    May 2011
    Default Re: My algae issues
    My bet is that it was caused by the algaecide that he added. Some of those will cause foaming.
    "He" is a "she" but nonetheless, I think that you are right. It continues to dimish.
    Oops! Sorry about that. Glad to hear it is improving. This is one reason that the only algaecide that we recommend for use is 60% Polyquat and even at that, most times you don't need any algaecide at all.
    May 2011
    Trust me, I've learned my lesson. I'll be interested in what you all recommend for winterization...particularly to prevent algae next season.
    We'll still be here in the fall. It's a big cycle. We help clear green pools in the spring. Then, when fall rolls around, we help with closing so that hopefully there will be fewer green pools next spring! Actually, the Pool Forum staff typically all pop onto the forum at some point most days in the winter, too. Just to see if anybody needs help and also because this forum is such a part of our lives that we would be kind of lost without it!
    May 2011
    I just tested my pool with my new K 2006 test kit. The DPD power top was open, so I lost most of the powder, but I was still able to get a reading with a bit that I found in the container.
    Here are my results:
    free Cl = 7.0 ppm
    combined Cl = 0
    pH = 7.2
    CYA = 0
    I went ahead and added another 3/4th gallon of bleach. I added five on Monday and have added 1 or 2 each day since. Due to the CYA reading, I went ahead and added some clarifier.
    Yesterday, I could vaguely see the bottom of the pool for the first time.
    I have a 7600 gallon above ground pool.
    Any recommendations beside patience?
    Keep adding bleach. In your pool, each quart of 6% bleach will add about 2ppm of chlorine. Until you get some stabilizer in there, you'll probably need to test it at least morning and evening and each time, add enough bleach to get back up to about 10-12pm. The more times per day that you can test and shock the pool back up, the faster it will clear. Also run the pump 24/7 while you are trying to clear this up. Backwash the filter as needed. Once you get it clear, then you can add some CYA.
    By the way, I don't understand your sentence where you said that "due to the CYA reading, I went ahead and added some clarifier." Clarifier has nothing to do with CYA. CYA is cyanuric (or isocyanuric) acid. Not clarifier. Don't add anything else right now except bleach and Borax if your pH drops any. And, you're right --- patience is needed.
    I would also call the company you bought the kit from and tell them the powder was spilled when you got the kit and ask them to send you a replacement bottle ASAP.
    EDIT: What company did you buy the kit from? Please email us at poolforum AT gmail DOT com and let us know.
    EDIT again: I read of two people today who had their kit arrive with spilled DPD powder. That is why I thought there might be an issue that we needed to look at. But, when I investigated it further, I realized that it was the same poster (True Blue) who had mentioned it in two different threads rather than two separate incidences. Thus, it is probably nothing we need to be concerned about. If it happened several times -- maybe -- but only once, I doubt it. I'm sure if you call them, they will replace it. Especially since we have problem sent hundreds of customers their way!
  1. I'm having issues!
    By krissy in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-17-2012, 09:18 AM
  2. Massive algae issues
    By Luke978 in forum Dealing with Algae & Slime
    Last Post: 05-03-2012, 11:24 PM
  3. Algae and now ph issues
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-24-2011, 09:39 AM
  4. Help! Pool Cover Issues and Leak Issues
    By b2001 in forum Pool Equipment & Operations
    Last Post: 02-17-2008, 06:34 PM
  5. Help! Ph and swg issues
    By SoCalBoo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-28-2006, 08:07 AM
