Results 1 to 10 of 13
Thread: Ongoing issues
    Default Re: Ongoing issues
    really, the only thing we'll have you address at first is chlorination and pH. Everything else can wait but we need to know what they are. Heavy chlorination should take care of the foaming, too.
    Do yourself a favor and buy a good test kit so you don't have to rely on the pool store. We recommend the Taylor K-2006 or 2006C. If you order it through the Amazon link in my signature, the Pool Forum makes a little money which helps keep this forum up and running. (Only buy from Amato Industries, however. Some of the other sellers through Amazon are substituting the K-2005 which you do NOT want.)
    Carl I have put at least. 4 gallons of 12% chlorine since saturday so I bet its the cya. Will get results tomorrow and post.
    Watermom looking at the test kit now. What the difference between the two? And I don't see it available from amato
    The kits are the same, except the "c" version has larger amounts of reagents in it.
    Keeping your chlorine above 12 ppm can take LOTS more than 4 gallons. You just have to keep testing and adding more until the pool clears up and the foam dissipates. The "swamp treatment" likely has created even more of a chlorine demand, and if your CYA was high at the end of last season, it also can breakdown over the winter into ammonia and create huge chlorine demands. THey can be overcome, but you need to be diligent about it.
    I just looked at the Amazon links. Amato Industries must currently be sold out of the K-2006. Probably all the folks that we are sending from Pool Forum buying all their inventory! That has happened before, but usually in a few days, they again are showing up as having them available. But, they DO currently show the K-2006C as being in stock. That one is a better buy anyways.
    Pool kit ordered...
    Water tested...
    Free Available Chl 0.12 - yikes
    Total Chlorine 1.17
    Combined Chl 1.05
    Total Alkalinity 107
    pH 6.9
    Calcium Hardness 104
    Cyanuric Acid 21
    Walmart was out of Borax so I picked up 5lbs ph increaser and 8 gallons of 12% liquid shock. Store clerk told me she would use 2lbs of the ph increaser and 4 gallons of the shock. Is that the right advice?
    Apr 2011
    virginia
    We still need to know a few pool details- especially size...
    The pH increaser will work, just a lot more expensive than the borax. I would shoot for a pH of 7.5, add however much of the increaser it tells you to dose based on pool size to get there, then just work the chlorine to clear the pool. Don't worry about anything else right now- pH between 7.0 and 7.8, and chlorine- probably 10-15 ppm chlorine until pool is clear, then we can work on the right numbers from there.
    The pH increaser is almost certainly Sodium Carbonate, also called Soda Ash, but better known as Arm&Hammer Washing Soda (not baking soda).
    It will increase your total alkalinity. If your pool is vinyl, it shouldn't be a problem. If it's concrete, tile, etc, I wouldn't add it. Instead, aerate your water to raise your pH without increasing total alkalinity. You can simply point the return at the surface so it bubbles.
    The 12% liquid chlorine is good stuff. You'll get an increase in Free Chlorine of 12ppm/per gallon/per 10,000 gallons of water. So if your pool is 30,000 gallons, you need 3 gallons of the LC to increase FC by 12ppm. You want to get your pool to an FC level of 15ppm given a CYA level of 21ppm. So she MAY have told you the right thing...depending on the volume of the pool.
    If your liner is vinyl, you want to stay at the recommended shock levels in Ben's Best Guess table. If you have a hard-sided pool, you can exceed it and speed up the algae killling.
    Correction: You have 20,000 gallons, vinyl. 4 gallons of 12% will increase your FC by 24ppm--too much for a vinyl pool with a CYA of 21. It can bleach your liner. IF you don't care about that (like me, with an old liner) 4 gallons should work spectacularly well. (that's what I did a few weeks ago, but I don't care about my liner fading--it's faded already). However, if it's a newer liner, you'll want to add 2.5 gallons of LC. That should boost your FC to 15ppm, which is what you need.
