Results 1 to 10 of 13
Thread: Somebody please tell me this is worth it....
    Lehigh Valley, PA
    Default Re: Somebody please tell me this is worth it....
    Hi Jen, hang in there. It'll clean up long before autumn.
    I had a green pool once when I went on vacation for 6 weeks in September and just left it. I had shocked it, put the solar cover on, turned the pump off and drove away. It was still very warm during the days and I expected it to go green. Still, it was a bit of a shock not being able to see the bottom of my 52" AGP when I returned, to see it match color to the surrounding fir trees.
    I can't remember how much chlorine it took but I do know that each day there was improvement. Getting it back to clear and sparkling took about 10 days of bleach, brushing, running the pump the entire time, backwashing the filter every other day, changing skimmer socks three times daily . . . it was a process and required frequent attention but it did clear up with just chlorine.
    It takes a lot of patience though.
    Largo, Florida
    Here's my before and after. Took less than a week in my case, following directions from this site. http://www.flickr.com/photos/14865808@N00/4857680807 Lots of chlorine bleach, a gallon or so of muriatic, some stabilizer, salt, and viola. I think I added some ployquat as well, but I've since stopped using it on a regular basis.
    I scooped and vacuumed all the junk I could (maybe 4 hours or so the first day). Then let the chemicals do most of the rest of the work (along with daily filter washes). I was sure I would have had to drain/refill when I bought the house too; but that was not necessary!
    May 2011
    Arkansas
    Thanks y'all. Those transformations are amazing. =)
    Old pool/ new owner =)
    32,600 gallon chlorine, inground, vinyl lined pool with deep end.
    Pump: Haywood 1.5 hp
    Filter: 300# sand filter.
    And they are not just odd cases. I opened to green slime and in 24 hours was 90% clear. In a week, I was crystal clear. Why? I didn't panic (I knew why I opened to algae, and what to do). I looked at my wife, shrugged, and she said: "You know what to do better than almost anyone."
    It's just not hard to do if you follow the rules, and rule 1) is: You need lots of chlorine, and it's best delivered as bleach or liquid chlorine (same stuff, only more concentrated.)
    It works!
    May 2011
    Arkansas
    Where do you buy liquid chlorine?
    Thanks for the pep talk. I was able to see the missing part of my vacuum this morning so I am happy about that! It will be less frustrating once my kit comes in.
    This year was the first time I took my cover off to find the green nightmare. 3 times, before I finally put a temporary fence aroudn my pool, my dogs and the neighbor's dogs jumped on my solid cover resulting in a whole lot of leaves making into the pool. I opened my pool on Saturday, added 5 gallons of bleach, scooped out 99% of the leaves and by Sunday night the water was blue but cloudy. By Tuesday the kids were swimming! Hang in there and follow advice from the great folks on this site!
    Update: Just saw your signature and saw vinly liner. My experience is that inground vinyl liner pools usually don't have drains in the deep end - mine doesn't. A couple times a week I take the vacuum head and throw it in the deep end over night to pull from the bottom instead of the skiimer. It works wonder in keeping the water clear. Before I started doing this I would occasionally get cloudy water. Since doing this, crystal clear! Also add a little DE to my sand filter when it gets cloudy now.
    Ken J
    Glenside, PA
    16x32 Inground, 20,000 Gals, Pentair WhisperFlo Pump WFDS-24, Hayward Sand FilterS310T2 (with occasional DE added)
    Apr 2011
    virginia
    Jen
    LC is available in some pool stores, and sometimes hardware stores/Home Depot/Lowes.
    Not available everywhere, though... I have to use regular bleach!
    Seeing the vacuum sounds like improvement! hang in there a little longer, it'll continue improving and you have lots of summer left!
