Results 1 to 10 of 45
Thread: keeping up
    May 2011
    Staten Island , NY
    Default Re: keeping up
    Yes its her pool. She wants help taking care of it but still wants to do a bunch herself. She works more hours than me sometimes 5 days a week. She tries to go off the top of her head what the FIL used to do and thats what doesn't help. He actually practiced the BBB method somewhat. When the pool cloudyness does finally clear up thats when she'll give in and at least give me some leway with chemicals. btw pool cloudyness hasn't changed. would it help if I were to raise the PH? It's currently holding @ 7.2. will check the #'s early in the AM
    May 2011
    Staten Island , NY
    OK leaving pH alone for now. dropping kids off @ school ....MIL went off to work then I can go work on pool. update around lunch time
    I'm not going to get into this one too much. Looks like Watermom and CarlD are giving you as much help as your MIL can stand.
    But here are two points to consider:
    #1 - DE filters will remove most anything that makes pools cloudy, given time. If you can run your filter 24/7.
    #2 - Live algae plugs DE filters pronto. If you've still got some, you need to kill it ASAP. Doing so will make clean up MUCH easier.
    #3 - It's quite easy to cause some bizarre forms of cloudiness that are hard to filter even with DE, if you keep mixing mystery chemicals. If you can 'lose' or hide the MIL's chem stash, that would probably help.
    May 2011
    Staten Island , NY
    I can see the bottom wooohoooo. I see patches of sand like debris on the bottom. Here are updated #'s
    FC 12ppm
    CC 6 ppm
    pH 7.0
    TA 80 ppm
    CH 80 ppm
    CYA 30-40 ppm closer to the 40
    I've been able to run filter 12 hours a day (MIL keeps shutting the timer off)
    have been back washing the DE filter and recoating the filter.
    Will go back there after lunch to vacumm and take another Clorine reading.
    I can see the light @ the end of the tunnell !!!!
    And I've come to the conclusion that my FIL is acting through MIL frustrate me to death.....lol
    Hey beast,
    I'm glad things are beginning to work for you, but please tone down the terms a bit. We pretty much operate on "must be OK in Sunday School" language standard here.
    May 2011
    Staten Island , NY
    10-4 will try my best
