Re: What to do next? High Alkalinity & Combined Chlorine, Well Water & Iron issues
Ok - ran my sump pump overnight for aeration and the pool sat all day without the filter running because our pump really overheats and we don't want to risk leaving it on all day. I'm really not trying to ask for advice then not take it, really. After reading Carl's post I think we have an issue - If you splash water on it, it sizzles - and I don't even know where to start with the pump. We have been back washing a lot, with the iron cleanup we did it at least 6 times over the weekend and pressure is in normal range.
Got more water tested today (pulled it following Ben's test sample instructions on website this time), and here's the results:
FC 0.8
TC Not run
ph - 6.9
Hardness 160
Alk 190
CYA 10
Copper 0.03
Iron 0.12
Nitrate 0
TDS not run
pH is where Ben said to stop the acid, and that is only after 1 gal. I didn't add any since yesterday. Should we add more to get the alk down or leave it and move on to the chlorine?
Also - I do have 3" tabs, should I throw one in the skimmer or just start with bleach? Is household bleach stabilized - will I need to add CYA?
Thanks again!
