Results 1 to 10 of 48
Thread: Pool still cloudy white. Been a week today... This stinks.
    Howell NJ
    Default Re: Pool still cloudy white. Been a week today... This stinks.
    Pool doc I read your post on the other thread. I do have a 2 speed pump and been using low at night and high during the day.
    I have the cart and sand hooked in series. I put the cart back in like you suggested. The pressures are normal there. Typically the sand by itself starts at 12 psi. With the cart installed the sand is at 8psi. Lower flow? It will filter better I would think. If I run it with both filters on low the flow is too reduced IMO. So I am running on Hi now.
    All #'s are still normal. Just cloudy.
    12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
    Howell NJ
    OK all #'s normal.
    Still cloudy.... Ho..Hum!!!!
    I will post afternoon the status.
    Howell NJ
    OK all #'s normal.
    FC 4
    alk 80
    ph 7.2
    cya 30
    Still cloudy. Filtering 24/7
    Ho Hum. Vacuum and brush everyday.
    Will probably copy and past this for tomorrows update. Will be two weeks Tuesday.
    Apr 2011
    virginia
    What's your CH? your other numbers look good, but CH can be screwy with cloud issues.
    Can you see your return water? does it look more/less cloudy than the pool?
    Howell NJ
    I tested hardness with my hach hardness test. It has the powder you add one scope. It tests at 1 gpg or 17.1 ppm.
    I will test CC when it comes down and I can see the results in the tube. Last time it was FC 1. then add r3 reagent and it read a 2. So that was TC 3, and CC 1? 2? But I have been shocking.
    Never heard of that test for hardness. The only powder test I'm familiar with is the FAS-DPD chlorine test.
    If you have a CC of 1, then you are fighting something in the water and need to continue shocking and try and consistently keep your chlorine level at about 15ppm. (How high have you been shocking to?) With a cya of 30, a cl level of 4 isn't gonna kill something growing in the water. I am not familiar with the units you used to measure your hardness level. Another thing I am wondering is whether your pump is too powerful. A 1hp pump is pretty big for a 6200 gallon pool. Too big of a pump on too small of a filter will not filter the water well because the pump forces debris through the filter with too much pressure and your sand can't trap it.
    Howell NJ
    The hardness test is ammonium chloride... I use it to test my well hardness level. I think its total hardness?????
    I have been shocking to above 13 ppm for all this time. I just started letting it come down to normal levels because nothing has been changing. The pool is white/blue cloudy.
    I have been adding DE and running the pump on low. So I understand the too powerful of a pump thing. The pressure does rise with DE but not without it. I have a new cartridge coming for my old cartridge filter that I am going to hook back up. It will not be here until tuesday.
