Hi everyone,
(I lost my first attemp to post here so maybe this is a duplicate, sorry)
Fourth year for our 33' by 16' fiberglass pool with DE filter. We use the CLfree system and we like it and yes I know some pros don't.
First two years I was only adding one half of the DE that I was suppoded to.
First three years I was adding DE in the filter cycle and not the rinse cycle.
I have never vacumed the pool as we use the Tiger Shark.
Last two years I used a lot of citric acid for a small stain situation, also used Metalfree.
Have always had some cloudyness to the pool.
Last week I opened the pool to crystal clear water. After running the filter for a day the cloudyness came back. My thought is that over the winter all the particles that caused cloudyness settled to the bottom. After filter was running they got stirred up and caused the cloudyness again.
Last Falll I cleaned the grids and soaked them in an acid water bath. I reassembled properly.
I believe that the filter is operating properly.
Plan of action: I'll add a double dose of clarifyer, see if it settles after pump off 12/24 hours and then vacume to filter cycle. If that does not work, add double dose of flocculent, wait 12/24 hours to see if it settles and then VACUME TO WASTE.
PH is 7.2
Tot alk is 100
CH is 250
Copper is .7
Thanks to anyone who can advise me.
