... I have too much material across the pool, with barely enough on the "sides" (it is a 27ft round, so there are no sides per-se, but I am referring to the sides perpendicular to the area that has too much material)...
I had sun on one side of the pool, the end with far too much material. Across from that end there is still a bunch of extra material compared to the area on the sides. I figure it will stretch in the sun on the sides, but what happens if after it fills I have too much material on the "ends"???
I already cut the holes for the main drains, so shifting the liner is out of the question, but it is not like it would matter, since we checked the pool before putting the liner in and it was properly round and exactly 27ft across from each "post"...
So, did they send me a liner that is oval or what???
I do not have enough material on the sides to use it as an overlap liner. This was a major PITA and a huge push to get this pool up this year still, just to run into this???
I have filled it only about 2/3rds of a foot full, just basically above the cove... I shut off the water for the evening and figure I will attempt to fill it more tomorrow...
Any and all input is apprecaited...
