Re: Nice to see a great site..
If you are using chlorine in your pool, you should be using stabilizer to help shield the chlorine from the sun. If you keep your pool adequately chlorinated, which means 3-5 ppm at all times until you get stabilizer in the pool, then you don't need to use algaecide, which can cause you more problems than it's worth.
