Results 1 to 10 of 36
Thread: eric
    Default Re: eric
    If it has been about a week since you added any stabilizer (CYA) so that you know it has all dissolved, then I'd add a little more to bump you up to about 40.
    is 7.8 the highest reading that your pH tester can differentiate? If so, was your 7.8 a true 7.8 or was it actually even a darker red than that?
    By the way, a BIG, BIG, thank you for becoming a lifetime member! That is SO awesome and we really appreciate it very much! Ben was very pleased to see that you had done so. We are very happy to have you be a part of our forum!
    Jun 2011
    Default Re: eric
    our taylor tester will test ph up to 8.0. how much stabilizer should i start out with? i have a 3 lb. bottle from walmart. we are glad to be a part of this forum too. you all seem to run a high standard when it comes to the language and what's allowed to be discussed. this is really refreshing in this day and age. based on the size of our pool will 16 oz of stabiler add 12ppm of CYA to a 15k gallon pool?
    Taylor K-2006 -- ~14k gal. 24 ft x 52" AG
    Meteor 20" Sand Filter Pentair 1.5 hp pump
    Default Re: eric
    16 oz. of stabilizer will add about 8.5ppm of CYA.
    The reason I asked about the limits of your pH tester is because if 7.8 is the highest your kit could read and you got 7.8, it could actually be much higher. But, since your kit can read to 8.0, then we know your 7.8 is actually 7.8 which is fine.
    Regarding our forum standards, yes, out of courtesy to our members and ourselves, we do run a clean house. We try to be fair, honest and polite and we expect the same in our members. At least one of the Pool Forum staff reads every single post on this forum and generally we all read all of them. Occasionally we have someone come along who uses some inappropriate language or content and we edit it and clean it up and ask them to refrain from doing so again. Generally one request is all it takes, but once in awhile, we have to remove a user who will not abide by what is expected. We want the forum to be a place people enjoying being a part of in their quest to take care of their pools.
