Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Thread: Just pulled cover off.. green swamp water
  1. #21
    Default Re: Just pulled cover off.. green swamp water
    Chlorine levels are based on CYA levels. If you haven't already done so, please take a look at the Best Guess Table in my signature below. If you drop below the necessary chlorine range, you risk an algae bloom.
  2. #22
    Jun 2011
    I looked at that before but didn't see why the ranges changed like they do. I guess algae is the answer. Does the cyanuric acid level decrease slowly with time?
  1. Opened for first time with old loop loc mesh cover green swamp
    By Gretzky99 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2013, 10:01 AM
  2. 27,000 gallon green swamp HELP
    By ms dean in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-29-2012, 02:38 PM
  3. Green Pool / Swamp complete with frogs...
    By JenLM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-13-2011, 03:11 PM
  4. cover off - green water - pump broken
    By masspool in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-09-2010, 03:58 AM
  5. Cover blew off some, green water on top now in the pool
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 09-02-2008, 10:56 PM
