Thread: filter short cycle
    Jun 2011
    Default filter short cycle
    Just opened pool this weekend and my filter won't run more than 1 hour without having to back wash never had this problem before.
    Jun 2011
    Default Re: filter short cycle
    Yes lots of algae also noticed sand after backwashing on ground
    That would explain the frequent need to backwash. The filter is catching stuff. So, it is doing its job. Might be a good idea to post a current set of water testing results taken with a drops based kit for us to take a look at.
    Jun 2011
    Thanks is it normal to lose the sand out of filter when back washing
  1. Seeking help with new pool- sand filter works barly for short time and no pressure
    By tallguyy808 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2012, 09:23 AM
  2. Filter Cycle Time
    By F Wegeners in forum Pool Equipment & Operations
    Last Post: 06-03-2011, 12:50 PM
  3. short sand filter cycles
    By jeffmarc in forum Above-Ground Pool Construction & Repair
    Last Post: 07-17-2006, 09:34 AM
  4. Water cycle
    By crosso in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-26-2006, 03:53 PM
  5. Timing the pump run cycle
    By kevincad in forum Pool Equipment & Operations
    Last Post: 04-11-2006, 07:32 PM
