Thread: How much Chlorine should I expect to use?
    Default Re: How much Chlorine should I expect to use?
    My pool is roughly the size of yours and my CYA is usually around 40ish. I typically add a couple of quarts of bleach per evening.
    Since your pool isn't totally clear and your chlorine had dropped so low (with a cya of 40 you need to keep the cl between 3-6 all the time or you risk an algae bloom), I would suggest going ahead and shocking your pool up to about 15ppm this evening after the sun is off your pool. An hour or two after adding the bleach tonight, test it to get the cl reading. Then, test it again in the morning within 2 hours of sunrise. If you haven't lost more than 1ppm of cl overnight, then you can let the cl drift down but if you have lost more than that, shock it again. Repeat the cycle until you do not have more than 1ppm loss overnight.
    Run your pump 24/7 while you are trying to get it clear. If, after you are past the losing more than 1ppm overnight cycle, it is still not super clear, you might try adding a little DE to your sand filter to increase its filtering capabilities. More about that here:
    http://www.poolforum.com/pf2/showthread.php?t=3742
    Welcome to the forum, Mark!
    mkessen Guest
    Thanks for the advice. The water is also now clear!
