Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 36 of 36
Thread: Using the K-2006
  1. #31
  2. #32
    Jun 2011
    Louisville KY
    Default Re: Using the K-2006
    Quote Originally Posted by AnnaK View Post
    Those test kits are fun, aren't they?
    At the bottom of the PoolCalc there's a feature called "Effects of adding chemicals" .
    It says that adding 180 oz of 6% bleach (the 2 bottles you bought) will raise the FC in a 36,000 gal pool by 2.4 ppm.
    Looks like you have things well under control and are on your way to a 5 Minutes A Day pool.
    Oh good. Thanks for the reassurance.
    I will look more closely at the pool calculator.
    Yes the kit makes testing way fun.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
  3. #33
    Jun 2011
    Louisville KY
    As long as your water isn't cloudy and your TA isn't high and you don't use cal-hypo, you'll probably be fine and don't need to bother with draining any.
    I have to add water periodically due to evaporation and a small persistent leak from my filter plug. It has not rained here in nearly two weeks, with hot sunny days in the mid to upper 90’s.
    I will monitor the CH level as I recall from reading the K-2006 guide that high calcium levels do something bad.
    Many thanks to you and all the folk here.
  4. #34
    Jun 2011
    Louisville KY
    Testing testing testing – the other day my CC test turned yellow.
    Until then it always went clear. The instructions say it may turn pink.
    What’s going on?
  5. #35
    usually partial bleach out from high chlorine (very high). Try the test again with more DPD powder (3-4 scoops). If it still happens dilute your sample 1:1 with distilled water and test with a 10 ml sample then multiply your number of drops by 1 to get the FC and CC.
  6. #36
    Jun 2011
    Louisville KY
    Right on as usual Evan.
    I had upped my chlorine dose to two 1.4 gal jugs to ward off any potential algae bloom since the temps are now in the mid 90’s here and I had a 4th of July party planned.
    So on a hunch yesterday evening I did the 25ml CL test with two dippers and the CC came back clear as store bought glasses.
    Thanks for the tips.
  1. Help with K-2006 results
    By Ohio Canoe in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2012, 02:58 PM
  2. Got my new K-2006 testkit...now what?
    By pmoneykitty in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-19-2012, 07:19 PM
  3. First start with K-2006
    By Vtattebury in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-31-2012, 09:31 PM
  4. Defective K-2006 Kit?
    By droweye in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-02-2012, 08:26 AM
  5. K-2006: Might have screwed up.
    By Willjay in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-02-2011, 06:05 PM
