Re: Using the K-2006
Watermom
You are doing great! TA at 100 is fine. Your CH is high but as long as your water is not cloudy, you're ok. Just don't use any cal-hypo and don't let your TA get high. BTW - The only way to lower CH is to do a partial drain.)
Thanks again Watermom – a partial drain, hmm. I have hard water here in Louisville.
From the water company - Pure Tap®, Louisville Water Company’s tap water, is moderately hard, at 159 mg/L or 9.3 grains of calcium carbonate per gallon.
So would a partial refill actually help lower my CH level?
Circa 1980 IG, VL, 36K Gal, DE, Chlorine
