Results 11 to 13 of 13
Thread: GREEN pool water!!! HELP!
    Default Re: GREEN pool water!!! HELP!
    Keep doing exactly what you're doing. Maintaining high cl levels, run the pump 24/7 and backwash as needed. It will take the filter a little time to clear out the dead algae. When you get to the point where you don't lose more than 1ppm of chlorine from sundown one day til sunup the next day, then hold the shock level for one additional day for insurance and then after that you can let the cl drift down. With a CYA of 60, you're maintenance level for chlorine will be between 5-10 all the time or you'll risk another algae bloom.
    Stick with using only bleach for the chlorine source now since your CYA is already at 60. Unless your SWC manual tells you to run the CYA at a higher level, I'd leave iit where it is at 60. Dichlor and trichlor will both raise it.
    Yes, and your pH is probably lower than you think if you tested it when FC was 30. So that's another reason not to use trichlor or dichlor.
    Blue is DEFINITELY an improvement from green!
    Apr 2011
    virginia
    did I read you have a sand filter? if so, you can add some DE to it to make it filter better/faster; otherwise, it sounds like you're winning the battle, just a little patience while the filter gets rid of the dead algae!
  1. Green water in pool
    By Dudek in forum Dealing with Algae & Slime
    Last Post: 06-07-2013, 09:19 AM
  2. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  3. New Pool ... green water
    By btokash in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-26-2012, 03:43 PM
  4. Green Pool Water tried everything Please Help
    By VickiP in forum Dealing with Algae & Slime
    Last Post: 06-04-2010, 07:47 AM
