Results 1 to 10 of 15
Thread: New to bbb method and cya question
    Default Re: New to bbb method and cya question
    Although anywhere between 7.2-7.8 is ok, I prefer 7.4-7.6.
    EDIT -- I just now saw that you are going to work to lower your alk. In that case, you'll want to drop your pH down to 7.0 and then aerate it back up. Be sure to read the link Jan posted for you above that explains the lowering alk process.
    May 2011
    Greenwell Springs La
    what should my target alk be ?
