Re: Salt water magic and Intex salt water/copper ionization system
UPDATE: I actually just got a resonse from the manufacturer of Salt Water magic. They are compatible with metal ionization. It doesn't actually remove the metal it just prevents from staining....so I guess my problem is solved....hopefully. Also...I want to add that modern copper ionization won't turn hair green, because of the minute amount of copper used....the old systems used much higher amounts and did turn hair green. Levels above .3 can turn the hair green from my understanding. The trick will be to see how easy it is to controll the level of copper or maybe I should say how well the machine controlls the level of copper. I anxious to see how it works for myself. My daughter is platnimum blonde...she won't be happy if she is platnimum green/blonde....
