So I am a newbie pool owner. My pool is an above ground (not permanent) 4,000. I don't really understand about the chemicals and what I need to add and how much. Pool has only been up a few weeks and only used 2-3 times due to it raining everyday for the past week or two. So far I have just been using half a bag of shock and 1 inch chlorine tabs. Here are my current levels
TC: 1
Bromine: 6
pH: 6.8
TA: 40
Stabilizer: 50
So since the pH was low, I bought some Aqua Chem pH up. I followed the directions and added 8oz. I added it about 5-6hrs ago and have had the pump running ever since. I just went back out to check it and it was still 6.8. What else do I need to do to bring it up? Should I add more pH up, if so how much? Would Borax or Baking Soda be better to add since the TA is low too? If so, much of it do I add. I am kind of on a tight budget so which ever method is cheapest and easiest. Thanks so much for any advice. If you need additional information, ask and I will provide what I can.
(That's why I put mine into the return stream--it helps dissipate it faster). Might want to make sure eyes are closed underwater for a bit, just in case...
